is there any trick to use callback with interactive-rendering notification? it detects corona IR only, not usual render.
if it is possible and ondra currently doesn’t create its script name yet, then this post should be moved to feature request. ![]()
sorry, is there any one know some info or anything else about this? or I explained in wrong way with wrong words ![]()
I need it because I want to write a script that do autodisable renderselection when render selection is enabled but the selection or object list is empty. I need this autodisable do what to do only when regular render pre-start not on IR pre-start. ![]()
cheers
