MAXScript colorPickerDlg crash with Corona Improved Picker
MAXScript method colorPickerDlg crash the application when Corona Improved Picker is used.
Can you tell us what version of 3dsmax and corona you are currently using? & Can you record a short video showcasing this problem on your screen?
Possible solution could be a fresh install of corona or 3dsmax.
Regards,
Avi
Corona version is 6 hotfix 1 and 3dsmax2021 (but it’s the same with 3dsmax2020, 3dsmax2019, 3dsmax2018, 3dsmax2017).
To reproduce:
  • set Customize > Preferences… > General tab > Color Selector > Corona Improved Picker
  • then go to Scripting menu > New Script > and paste > colorPickerDlg (color 128 128 128) “Title”
  • MAXScript editor menu > Tools > Evaluate All
  • The color picker dialog will show up, move one slider
What I experience is 3dsmax instant crash as soon as I move one slider in the color picker dialog.
Sometimes it gives an error (see image below) and then crash as soon as you try to close the dialog.
No issue with the color selector set to the default one.
I tried your suggestion, at least half of it, and uninstalled/installed Corona, but issue is still there.
Thank you for reporting this bug. I was able to reproduce it following your steps. I have reported it to our dev team for further investigation.
Regards,
Avi
(Report ID=CRMAX-448)
Happy to help!
This is fixed in v7 RC4.
Thanks,
Rowan
