Maxscript - Corona sun and targeted lights - get the yaw and pitch
Hi anyone out there that can help with a mathematical / maxscript question.
I need to translate Corona sun and target lights pos and rotations to get me the yaw and pitch.
How can I do this? “It times like these - Dave Grohl” I wish I paid more attention in Maths class!!
Is this even close?
 /*  x,y,z,roll,pitch,yaw */
 sun = selection[1]
 roll = sun.rotInParent[1]
 pitch = sun.rotInParent[2]
 yaw = sun.rotInParent[3]
There’s multiple different ways people are viewing this. This is just one page I found:
https://www.quora.com/How-do-you-represent-Roll-Pitch-Yaw-in-terms-of-X-Y-Z-axes-in-space
Cheers!
I would use a sun without a target (as suns position is irrelevant in corona), and just worry about the 3 axis rotation.
Try the below:
 sun =Coronasun()
sun.name = "scriptedSun2"
sun.position = [0,0,300]
sun.targeted =false
fn easyRotation obj x y z =
			try(obj.rotation.x_rotation = 90-x)catch() -- Invert the height as 90 should be up and 0 should be down for the sun
			try(obj.rotation.y_rotation = y)catch()
			try(obj.rotation.z_rotation = z)catch()
		easyRotation Sun 0 0 0
That’s not what I was after. I managed to sort it out.
convertDirectionToYawPitchAsPoint2Value function
Translates any items point3 direction and returns it as
yaw and pitch in degrees as a point2 value.
Usage: convertDirectionToYawPitchAsPoint2Value <selection>[1]
Returns: [<expr>, <expr>]
fn convertDirectionToYawPitchAsPoint2Value theItem =
  direction = theItem.dir
  yaw = atan2(direction.x) (direction.y)
  pitch = asin(-direction.z)
  return [yaw, pitch]
-- print ((convertDirectionToYawPitchAsPoint2Value $)[1] as string + " yaw")
-- print ((convertDirectionToYawPitchAsPoint2Value $)[2] as string + " pitch")
OK i see!
Glad you sorted.
