I’m trying to put specific vray parameters in the VFB framestamp, e.g. Imap parameters, Lightcache, etc.
Reading the help files I would suppose the right way to achieve this would be writting down the specific maxscript parameter name preceded by the “%” character.
For instance, writting down “vr.gi_irradmap_minRate” in the maxscript listener works fine, giving me the corresponding value. But when writting “%gi_irradmap_minRate” on the framestamp edit box I get this exact text on the image and not the corresponding value…
Along these same lines, is it at all possible to show any property of an object in your scene? For example, could you do %“$Box01.width” to show the wdith of object Box01 in your scene?
Okay, I’m trying the prerender script method, and it works on my inital render, but the frame stamp string doesn’t update as it progresses to new frames. I am guessing this is more of a scripting technicality issue than a vray one, however I’ve use pre-render scripts succesfully for loading irmaps before, so I’m not sure why this would be different..
for my basic test here is what I have saved as a pre-render script
When I first hit render it works, but if I try a sequence where the box height is animated, it doesn’t update through multiple frames, it uses the first value that was valid when I initially hit render. (Not always frame 0’s value, but whateer the time in my viewport was when I hit render)
I’ve tried assigning the script to both pre-render and post-render, but the framestamp still never updates. ?
Just wanted to post and say thank you, got it working properly!
For whatever reason, a preRenderFrame callback alone wasn’t working properly, but I was able to get it working fine by loading the script into 3 different callbacks, preRenderEval, preRenderFrame, postRenderFrame.
