hello, im trying to write a few tools to speed up/facilitate a few things in our workflow but i can’t find any documentation referencing /descripting methods available to maxscript concerning corona (access to render elements, and so on)
Any information would be welcome
ps :i saw a link to a wiki that seems to not exist anymore.
Hi, sorry, we are deprecating our old wiki and will move the data from there to our documentation portal ASAP.
Can you list the exact things you are interested in?
Some more handy Maxscript I found over the years to speed up Corona Workflow;
Denoise set to on with all Render Elements:
local RE= maxOps.GetCurRenderElementMgr()
local REcount=re.NumRenderElements()
--for i=0 to (re.NumRenderElements())-1 where (findstring ((re.GetRenderElement i)as string) "LightSelect") != undefined do
if REcount != 0 then
( for i=0 to REcount-1 where (hasproperty (local El=(re.GetRenderElement i)) #usedenoise) do
( if El.usedenoise then
( format (El.elementname+": skipped because UseDenoise is already enabled\n")
) else
( El.usedenoise= true
format (El.elementname+".UseDenoise: "+(if El.usedenoise then "Enabled" else "Disabled")+"\n")
) else
( messagebox "Your RenderElements is empty :)" title:"Denoise all RenderElements"
Clear Render Element File Paths:
re = maxOps.GetCurRenderElementMgr()
for i = 0 to re.NumRenderElements() do re.SetRenderElementFilename i ""
Create Render Elements:
-- set a list of render elements.
elementlist = #(CESSENTIAL_Reflect, CESSENTIAL_Refract, CESSENTIAL_Translucency, CMasking_ID, CShading_Albedo, CShading_Alpha, CShading_Lightmix, CShading_Lightselect, CShading_Shadows, CMasking_WireColor, CTexmap)
re = maxOps.GetCurRenderElementMgr() -- get the current render element manager
re.removeallrenderelements() -- remove all renderelements
re.numrenderelements() -- get number of render elements
theManager = maxOps.GetRenderElementMgr #Production
theManager.numrenderelements()
rendoutputfilename = "c:\\test.tif"
-- adds all renderelements to be rendered.
for n in elementlist do
re.addrenderelement (n elementname:("OMP_" + (n as string)))
format "\nAdded % renderelement" n
rendsavefile = true
setsilentmode true -- used to avoid error message when checking the filename of element
renderSceneDialog.open() -- open Render Dialog -- get all render elements set and return name of render element and output filename
for n = 0 to (theManager.numrenderelements () - 1) do
el = re.getrenderelement n
format "\nGetting % render element" el.elementname
format "\nRender element outputfilename: %" (re.GetRenderElementFileName n)
