has anyone else had an issue with switching visibility of render layers in the render setup window ?
I’ve started to have problems where I’ll try to switch to another render layer but nothing happens.. the progress bar bottom left of Maya UI says 100 percent but the layer hasn’t switched over .. maya doesn’t freeze , its just you can’t go over to another render layer .
.. hopefully someone can make sense of it but it looks like in my case its a vray render element , I had to delete all the elements and this fixed the issue
see below
in the script editor it displays this error message :
# # File “C:\Program Files\Autodesk\Maya2018\Python\lib\site-packages\maya\app\renderSetup\common\devtools.py”, line 7, in wrapper
# # raise RuntimeError(“Abstract function called from: " + self.__class__.__name__ +”.“+ f.__name__ +”(“+ str(inspect.getargspec(f))+”)")
# RuntimeError: Abstract function called from: VRayRenderElementStrategy.contentType(ArgSpec(args =[‘self’], varargs=None, keywords=None, defaults=None))
looks like similar issues , maybe brought on from other reasons , has happened before in maya 2017
the issue is that I can’t make any overrides on the render layers for any of the render elements currently, as this is what seems to cause the problem…
i’m trying to have a particular set of render elements active on one render layer and inactive on other render layers .. if I create an absolute override for say a velocity element , and then try to swap visibility to another render layer i can’t…
yeah, I’ve been having issues with render elements and the new render setup system. I get a python error when I try and select any of the AOVs in the render setup window myself. As a workaround, I just created my elements in the master layer.
You can also switch it back to the old system in the prefs.
Just tested it. It has something to do with Update 1, but we are yet to find out what exactly. This problem was not there without Update 1. We’ll keep you informed.
This is already fixed for the next release, which will be 3.60.02 and it should be out pretty soon. The fix is already in the stable nightly builds, so if you have access to those, you can get the fix with any of the latest builds.
