I updated this weekend to test the update.
I have 2 Render Nodes: Both are Threadripper 1950x 128GB RAM with RTX 3090
Workstation is Threadripper 3970x and also has a RTX 3090
All machines have latest Win 10 Pro, Nividia Driver 496.13 and lastest Maya version 2022
Our internal network is 10 Gbe on all machines.
DR works fine on CPU in Progressive and Bucket
When we switch to GPU Cuda or RTX in either Progessive or Bucket the Render Nodes join and satrt but then stop immediately leaving the workstaion GPU to carry on on its own.
Re-installing Vray 5 Update 1 on all machines work fine.
Are there any error messages in the log? Does this happen in every scene? If not, could you send the scene in question via the contact form so we can take a look?
Hi, It is happening on all scenes. We have updated to the latest nighlty and the problem persists.
We get the following error message in the log.
The error dows not occur in CPU renders
[2021/Dec/4|10:58:08] [510 MB] CUDA renderer requested.
[2021/Dec/4|10:58:08] [510 MB] error: Error loading plugin library “C:\Program Files\Chaos Group\V-Ray\Standalone for x64\vray\bin\rt_cuda.dll”: 126: LoadLibrary failed (126): The specified module could not be found.
[2021/Dec/4|10:58:08] [510 MB] 0 plugin(s) loaded successfully
[2021/Dec/4|10:58:08] [510 MB] error: [RTRenderer::loadGPUPlugin] -1: Failed to load CUDA renderer plugin from “C:\Program Files\Chaos Group\V-Ray\Standalone for x64\vray\bin\rt_cuda.dll”
[2021/Dec/4|10:58:08] [510 MB] Using low thread priority.
[2021/Dec/4|10:58:08] [510 MB] Max ray intensity is enabled: rendered result may have incorrect brightness.
[2021/Dec/4|10:58:08] [510 MB] error: The bucket sampler could not acquire V-Ray GPU interface.
Thanks for the report. The issue is reproducible and I’ve logged it for developer investigation (internal bug-tracker id: VMAYA-10922).
I can confirm this is now fixed.
