Hello, there appears to be a bug with vray 7 and Maya 2026.3.3. This issue does not occur in Maya 2025 or Maya 2027. When loading a VDB from Embergen or simulating Phoenix, when in IPR, the volume does not update when advancing to the next frame.
No problem with Maya 2026.2 with V-Ray 7.40.04. Will install 2026.3.3 and report back. In the meantime, double-check if all V-Ray/Phoenix plugins are loaded correctly.
EDIT: No problems with Maya 2026.3.4 either. Testing with a sample embergen .vdb. Do you have errors in the Maya script editor/v-ray log?
Hey Hermit Crab, thanks for the quick reply. After you confirmed its working on your system, I reset Maya’s preferences and it’s working now. Sorry for the false alarm.
