Maya crashing when scattering multiple assets
Hello. I’'ve tested this a bit and we need a hotfix.
Maya crashes when scattering multiple assets and you ie. change diffuse color on their shader. does’nt matter what asset is used to scatter.
Can anyone reproduce this issue?
Have tested with vray 74004 or 74002, maya 2025, 2027
Is this for Maya or Houdini (this is the Houdini section)? Also, the repro steps and the versions you use would be nice.
edited my post. thanks
sorry posted in houdini. should have posted in maya. can you move it?
I reproduced it. Will log it for a dev fix immediately.
EDIT: Logged as VMAYA-14022.
A dev informed me that this was actually fixed in the stable builds. Mind if you try it out?
Thanks a bunch. Will try it out now
This seems to have fixed the issue. Thank you
