Maya keep crashing when using IPR
That’s exactly where I went to check and it shows no SP.
Tashko, are you able to re-produce this crash in Maya 2014 SP4 with the sample file I uploaded?
The same happened here after installing SP4 so I went through a new installation process with Maya 2014 SP3 and now IRP/RT works more stable with your scene. Just a few minutes of testing but no crashes while working on the scene lighting.
Funny that SP3 is more stable than SP4 in this regard. Can you confirm it’s good to go in SP3 after some more tests on your end and I will update my Maya 2014 to SP3.
Thanks!
I think it is save to update to SP3.
Thanks Tashko. Just did the upgrade and will report here if I run into the same issue.
