Maya - Phoenix Shader Preset
Does anyway I can copy the same shader from one Phoenixsim to another? It’s kind tricky to get a nice realistic fire shader. It took me a while to get what I want so I want to use the same shader for all of my fire.
Any tip would be helpful. Thanks
Yup, check saving and loading render presets to a file - this is in the Rendering rollout :slight_smile:
Hi Svetlin,
I saved rendering preset out as a mel scrip but when i load it in. It giving me error
// Error: file: C:/Program Files/Autodesk/Maya2017/phoenixfd/scripts/AEPhoenixFDSimulatorTemplate.mel line 1611: No object matches name:
Ouch, sorry, I missed the Maya part - this is working much friendlier in Max right now. Let me check if I can get this error as well.
Thanks Svetlin
Maya just doesn’t work well with others =)))…Max seems more stable with Phoenix and Fumefx. Also, Vray work better with Max
The bug is fixed in the latest nightly build.
Cheerz!
Thank you George.
Cheers,
