When Maya Batch Render is executed on “Windows 10 + Maya 2022.3 + Build 5.20.01”, mayabatch.exe is not exited after rendering is completed. (Same for Nightlies 20220107)
This issue does not depend on the content of the scene.
There seems to be no problem with Maya 2022.2.
I can’t manage to reproduce the issue. Can you share more details on how you start Maya Batch? Also do you use any other plugins and does disabling them help? Can you check if both installations use the same environment variables?
There was a detail by direct mail from Mr. michael.
Redshift Render has the same issue,
If comment out (do not load) “bifrostGraph” and “bifrostGraph” from pluginPrefs.mel as shown below, there will be no problem with Redshift.
flat if this happens with arnold or maya software, its likely not related to vray. Indeed a clean install should fix the issue perhaps. We render in maya 2022.3 all the time and no issues there.
We’re experiencing this problem too regularly - currently causing a lot of trouble. The maya batch process does not close down, often stopping a new batchrender from starting.
We’re running Maya 2023.3 and Vray 6 (v6.00.03 from Dec 6 2022).
