maya's equivelant to max's 'Overal Mult' setting in processing parameters?
trying to match some shader from max where they tweaked these textures using the Overall Mult setting in the processing section of the vray bitmap parameters.
hope this is the place to put this post.
Shouldn’t a simple multiplyDivide node (multiply mode) do the trick? Connect the input to the image and set a multiplier of your choice.
Hello !!
the tip from hermit is very correct !! But you can play with others nodes for textures like as ColorComposite, Layered or VRay layered.
regards
ah sweet, mult divide node did it thank you!
