Maybe a solution for DR bug
Thats not the issue I was having. Once I found out which machines were causing the fog to render different(/darker), I opened the scene on one and rendered it with no DR (no maps in the scene) and it came out fully darker.
Almost like one machine read the fog volue as 1, but the other was reading it as 0.01. Only fog that this issue came up with, tested loads of other materials.
Units were setup the same on both. Not a problem if you only ever use one machine, but I ended up having to strip all the fog out and tint the glass in post.
That’s unfortunate.
After this movie ends I’ll have to run a heavy fog test and see what the results are on our farm.
I would just like everyone to be aware of that the devs might have solved this in the latest beta. We’re looking into it right now to see if the 2.0 beta 3 will have the same issues.
Thread:
http://www.chaosgroup.com/forums/vbulletin/showthread.php?54013-Brightness-changes-on-farm-renders
Thanks Fredrik for this note.
