Melting a sheet of glass
Hi We have the scene where jet flames must melt a hole in the sheet of glass. Anyway to do it with phoenix? Thank you
like this video https://youtu.be/A4GDwSV1kyc
Hmmm, you could use a Phoenix liquid sim vith high viscosity for the glass, but a soft body plugin or a cloth plugin could work better for that purpose. If you go with a viscous sim, you could use a mapper to reduce the viscosity and melt the fluid. There is also a jet engine example scene somewhere around the forums as well.
