Hello everybody, i’ve read some threads about the memory heap damaged problem that i’am having, that you’ve just have to restart and it goes away.but not with me!! i still have the problem en i cant render 3500px or higher anymore.
Ihave allready reinstalled max and vray,The errror was away for half a day but then it came back again.
the system i’am working on at work is:
Dell dualcore 6600 2.4 ghz/2gb ram Windows Xp Prof
256mb ati radeon x1300pro
Where running Max6 and Vray Advanced 1.5rc3
Is it because max6 an the vray version are not very compatible Or the system.
It worked fine for a couple of months but now i’am really going ballistic. please help
This is just a warning; it will probably not affect the operation of 3ds Max / V-Ray in any way. Things have improved considerably in newer versions of 3ds Max in this regard though.
Yes i’ve read in the threads that it doesn’t matter and its just a warning. but the problem is that max/vray is not using the comp to its full capacity! The CPU only goes to around 9%
And back down again.
Iam rendering the file in max9 and everything looks allright for now CPU is up to 100% and its doing its thing.
That why i think its has something to do with max6/Vray or maybe some windows update
does anybody have some experience with the same problem
Yes and it started the last couple of weeks where thinking about reinstalling (format C) the entire computer.
You can’t confirm that the max6 and the vray version the where are running is the problem?
Because it would be logic to me because of the older version of max and the Vray version that where running is build voor max8 at least that what the description says.
