Ever since I started using vray I have faced regularly a nasty memory problem. Sometimes even a simple house model eats all my memory(24 gigs.) Does anyone know what’s causing this? I am using max 2012 and vray 2.0 and windows 7 64 bit.
I have one problem scene right now that’s totally unusable. I hope someone can help here.
edit: Only thing that has changed after I migrated from brazil 2 to vray is that I started using color correct plugin. Does it have something to do with this problem. All the files in my current scene that does not have color corrected materials work just fine. All the files that are using color correct have memory leak. Is this a known problem? Is there any workaround for this? I like using color correct when using gamma 2.2. Is there a better option with gamma 2.2 than having color correct plugin?
I found out the problem and it’s max’s motion manager. I found out a script that disables it and cleans memory. I just merged one light from a file sufferering from the memory problem. One light caused the memory usage to jump from 3 gigs to 15 gigs. I had to run the clean memory again. Quite annoying problem
Yep, It’s about tracknodes. I don’t know if tracknodes are connected to vray, but I didn’t have this problem with brazil 2. It’s easy to run the script when encountering defected scene. So problem solved.
Here’s the script I use now. I found this from autodesk forums. There was a very long thread about the same issue and finally someone created this script. gc() part can take some time if scene is heavily corrupted. It can take several minutes.
t=trackviewnodes;n=t[#Max_MotionClip_Manager];deleteTrackViewController t n.controller
and run this to clear memory
gc()
