Memory resources limits problem
is it possible to do in Сorona dynamic memory limits, for better management memory resources on different render nodes in distribute render /same in Vray/
Now,If in render farm located some different render nodes from 8GB to 32GB memory, it does not work well with Corona Render on heavy complex scenes/
This is not the kind of solution you are seeking, but maybe you will find it useful. In the newer versions of Corona (daily builds - https://coronarenderer.freshdesk.com/support/solutions/articles/5000570015 ) we have a new warning system that will let you know that you are running out of RAM (it works in regular and distributed rendering). You can check it out in the newest dailies (keep in mind they may not be 100% safe to use!) or wait a bit more for the official 1.3 release.
Thanks for answer/
just because of this /last Daily build with warning massages/, I drew attention on this problem/
I hope in future it is possible to somehow solve this/
duplicate, there is already request for out of core/memory handling improvements
