quick question…since when does the mesh light cast a self shadow???
Please have a look at the image below, inside the chandelier there is a box mesh light and its quite evident on the light fixture that the mesh light is casting a shadow of itself.
If i use vray sphere light its not doing this…is this a bug or a property of a mesh light? Should not the mesh light be actually shining from behind the fixture?
The light fixture is double sided material - actually a shelled object with a 0.5mm thickness.
Is there any way to avoid this? So the light behaves like the sphere light???
This seems to be a problem in the latest official versions, but I think there is some improvements and fixes ready to be added for the next service pack release. Can you post or send this scene to support@chaosgroup.com to verify that? I just want to test with your setup.
It does the same thing when i make the mesh light out of a capsule object…still casts self shadows…anyway, i will send part of the scene for sure in the morning
