Metallic map
Guys, i have got the metallic map from substance painter. What map should i connect it to in Corona Mtl legacy? (reflection, diffuse map or maybe to mix something in slate material editor?) help pls
Why do you want to use legacy material? Corona physical has dedicated metalness slot, you don’t need any fancy setups anymore.
