method for sparkly highlghts
Anyone know how best to achieve nice sparkly highlights in an animation, for example on halogen spot lights etc. Is there a specialist plugin that is compatible with vray?
You can do this with Lens Effects and/or Blur (depending on the effect you’re after) in the Environment Rollout in MAX itself.
and does that work with Vray ?
Should be able to do this with Lens Effects by using the Unclamped Colors option. To get it working with VRay you need to turn on the Unclamped color G-Buffer channel.
--Jon
