Hi, I have 2 annoying problems in Vantage that I couldn’t found any answer. Maybe I can found people at here who had and solved same problems.
1- When I try to delete an object, Vantage crashes and pop up minidump issue. I attached an image for this. Searched for this but nothing solved the problem. I can’t delete anything in my scene, this is very very annoying.
2- This problem is even worse than the other one because when the two are combined, it becomes incredibly annoying. I add objects from Cosmos Browser to the scene and duplicate them using Ctrl+D. I save the scene this way and exit. When I reopen the scene later, all the objects I duplicated with Ctrl+D are scattered to the 0,0,0 coordinate or random coordinates. This happens every time and there are hundreds of objects. Since they pile up on top of each other, putting them all back where they belong is a very time-consuming and frustrating task. I can’t delete them either because of the software error mentioned above, which causes the program to crash. Every time, I have to select and hide them all and considering I’ve done this dozens of times, the scene filled with an incredible number of hidden objects.
I hope there is someone there who has experienced and solved these problems.
Are you using Vantage 3.1.1 ? We fixed a crash when deleting objects in that version.
We have another ongoing issue with deleting objects. It manifests when the “Original Camera” was (somehow) deleted.
The only workaround for now is to examine your .vantage file, find
“deleted”: [{
“scene_name”: “Original Camera”
and remove the “scene_name”: “Original Camera” part (and the preceding comma if any).
Greetings,
Vladimir Nedev
Thank you for reporting this.
The first issue with the crash on object delete - we suspect that the crash is caused by a line in the Vantage file > Deleted original camera ; and we are working on a fix for it.
A temporary solution until we release a fixed for this, would be to edit the .vantage file using a text editor and remove the lines as shown here:
Only the marked area should be removed - if those lines exists in “Deleted” section of course.
As for the second issue with scene reload with many Cosmos duplicates. I can get it here and will do some more test before logging it as a bug report. Can you try to distribute them using the Scatter node as a workaround ?
The cloned objects positions reset is now logged as a bug and we will post here when the fix comes out.
The crash when deleting objects with files with deleted orig. camera is fixed for the next Vantage release.
