Hi folks,
I’m currently testing alpha6 with DR. Works like a charm. ![]()
But I noticed that using displacement on the carpet makes my slaves crash one after the other. It seems that they run out of memory (16gb).
Is there any way or setting which manages the memory consumption I might have been missed?
The rendering of my test scene below is using almost default render settings. Hope you like ![]()
We got same problem! The write Fail, Fail… I thought its a problem of my net, but I looks like we are not alone!)
Ah, ok thank you! I found it
I will give it a try.
BTW: Is it normal that if you interrupt DR while initial pass , max crashes?
Cheers, Dirk
how did you make the worn leather, thats a little gem. You mind showing us your material editor?
oh… you unwrapped it, it looks magnificent! thanks for showing.
