The wait for version 1.0 of Corona is killing me, but A7.2 is doing the job very well
Here’s is a 4 hour project from start to finish (before click Render)
modeling: Sketchup
render: 3DsMax + Corona A7.2
resolution: 1920x1080
render time: 1:30 per frame
passes: 485, but at 400 was clean enough
As of now, I’m working on a couple of kitchen projects and I’m quite impressed about the results you have achieved by using Corona. These images are crystal clear. How much passes did you run until get rid off the noise. Did you also apply some specific sort of PP?
Only now I’ve seen your reply…!!! Do you need answer after 120 days with no reply from me?
