Minimum passes on Render Settings
I would like a implementation of the minimum rendering passes in Render Settigns (overriding other parameters, or something like that)
Hi, I may have understood your request but are you referring to the “pass limit” option that is available in the scene tab in Corona render setup?
I thought the same, in some cases it would be helpful. I would like to have a switch between “Or” and “and”.
Let’s say you have a limit of 10 min and noise level of 5%. (or passes, doesn’t matter)
If you choose “Or”, it would behave like it does now, it stops rendering when it reaches 10 min or 5%.
If you chose “and”, it would stop after 10 min and 5% noise.
Hello, good morning everyone!
I wasn’t very clear in my request because I wrote in a hurry.
My suggestion is that there should be an option for a minimum number of passes. For example:
I want to be able to set an image to render for 10 minutes or at least 5 passes (even if it takes 15 minutes), if the 5 passes are completed within 10 minutes, the rendering would stop at 10 minutes.
I hope I’ve been clearer now.
This type of setting could also apply to time and noise level, as lollolo suggested.
Thank you,
