Hi Enscape Team,
Im using Revit Enscape to render my toilet, but as you can see, the mirror is relecting the exterior background not the cubic. Is there a way to fix this issue? Thanks!
This is Enscape Lifetime Bug, You gotta get used to it 8o
Thanks for your post!
Right away, please check out this FAQ article here. It goes into a bit more detail regarding how our reflections work - Also, having an RTX card helps to some further extent, and making sure that the Rendering Quality is set to Ultra when possible (Visual Settings).
If that doesn’t do the trick, you may also want to increase the thickness of the walls which let part of the sky through. Doing so should also help with the light leaking which seems to occur in the top right corner of the scene.
