I don’t even know what to do to work around these weird reflections… The door is flat, and the shadows?? The wall changes color mid wall, the towel ring is weird… the dropdown faucet is…??
how do I do mirror in Enscape lol…
@benjaminriendeau , thank you for your post.
Please be so very kind as to refer to the following FAQ article I’ve created:
Why are some of my objects/parts of my project not displayed in reflections?
I hope this helps. As mentioned in the article, we always strive to improve this behavior as time progresses. ![]()
I’ve read similar threads, I just noticed that your team said they were trying to fix it for V2.3… so I don’t know it seems a must now
We continously improve that. The next version will probably show textures and better lighting in the reflections. Please understand that reflections in real time computer graphics are a complex thing and will remain partially unsolved for quite some months. But we are on it!
I have a suggestion, Thomas.
For material that uses the keyword “Mirror”, can Enscape automatically place an invisible reflection probe near the mirror so that it can provide the highest possible quality of reflection for the mirror?
Also the idea of being able to manually place reflection probe/planar reflection helper can really brings Escape rendering to the next level for users who demand ultra quality.
Thank you.
The weak reflections and no workaround are a big problem for me too. An advanced workaround would be very appreciated.
Maybe for non-RT-VR images Enscape renders a view from the camera at the mirrored position and map it to the mirror. Maybe it double the render time, but for final still and animations it would be no problem. For VR usage it’s not so much a problem to have bad reflections. A keyword could allow to enable this extra calculation.
I think in your particular case, the next version will help you a lot because the missing textures in the reflections are very obvious. This will be resolved, maybe even in an upcoming preview version.
What I usually do to work around this is instead of a clear reflection, add some roughness. 10-15% It will blur the reflection enough to hide some of those things but will give you colors and shapes. Not the best effect but it works for me.
Thanks, and what about Glass reflection, aka chandelier style reflection, will this be a common fix?
