Mirror Reflection Distorted
Getting mirror reflection distorted, tried phone tag setting and with new tag also but same.
Any idea to fix reflection…?
Thanks.
mirror test.c4d (1.49 MB)
Change phonge angle to 0 or delet it.
if 0… then hole circle edges goes wrong…!
I’m not a C4D user, but I’m guessing your geometry is messed up…
I second that. The cleanest solution would be to add support loops around cut holes to help with smoothing.
there is support loop and no SD used…!
Thanks Ben, it works.
You’re welcome man! :smiley: For those wondering, geometry was the issue.
