Mirror reflection issue
I’m discovering Enscape on sketchup make 2017 and it looks awesome. I make tries before deciding to buy it.
I have an issue with mirror reflection. Is this a Graphic Card pb (HTX 1660 TI) or did I make something wrong ?
Thanks for help !
@tomsoel , please kindly check out this article here. Also, welcome to our forum!
Also, make sure that your Rendering Quality in the Visual Settings is set to Ultra, if you want to have best reflection output possible. Just in case you haven’t already.
Mirrors are not consistent. Depending on the scene this may be all you can expect. This one of the compromises in using Enscape.
Ok thx for reply.
I’ll make tries.
It also helps if you position yourself in a way where most of the objects are actually visible, as much as possible. Everything which is already on your screen has an easier time being reflected properly. :slight_smile:
that error like a “feature”, from first version. i dont know when they will fix it
This is one of the most common draw back of Enscape. You cannot get rid of it. It appears to be the most disturbing thing while designing something. When I have to place a mirror I try to put that in such an angle so that it cannot be seen directly so the noise is a little bit less considered. Try to keep focus on the larger object so that the noise cannot be seen with an open eye.
You are absolutely right, this is the way I use to eliminate noise.
We’d more than love to “fix” this if it were that simple, but since Enscape is a real-time rendering engines there may always be some drawbacks like not having perfect reflections for example to allow for proper navigation and to avoid causing performance issues - still, you can all be very assured that better hardware in the future will also allow us to furthermore improve our reflections substantially.
Based on the image in this thread, we improved these kind of mirror reflections. You will see the result in one of the upcoming preview versions.
