Mirror reflections getting blury when rendering an animation
I am trying to render out a simple animation of a bathroom.
The reflections in the mirror looks ok at the beginning of the animation but the more frames are being rendered the blurier the mirror reflections get.
I do not have any motion blur activated and can not figure out a solution to this problem.
When I turn off “reduce flickering” the problem no longer persists but other problems arise - the animation flickers and is unusable. Your help is needed and greatly appreciated.
Try using Preferences->Render Defaults->Optix Legacy Mode.
What’s your the setting for your reflection bounces? I usually bump up mine to the max setting.
Thank You npg - this worked!
Hi Luma3d. I have experimented with the bounces but it did not resolve the issue. Problem was with the denoiser and switching to the Legacy mode solved the issue. Thanks for your response.
Hi, maciej_janikowski. What version 3dsMax are you using?​
What is Optix Legacy Mode?
Would really like an in-depth tutorial on all these hidden away settings and what exactly they do…
