Cant add a bezier float node to the absortion distance of CoronaMaterial in Slate material editor, the parameter is not visible. Using Alpha V7
UPDATE: the parameter exist but has another completely different name.
+1 to a naming consistency revisión of corona material.
Absortion distance 21,0 cm = Material attenuation 0,21
Absortion color = Attenuation tint
Also “Reflection Bluriness” change to “Reflection blurriness” same for “Refraction Bluriness”
naming was fixed in daily builds, please check it for more inconsistencies, if you have the time
please could i get acces to daily builds?
You are doing an outstanding job.
