Hi to all,
I’ve encountered a strange problem with DR rendering.
I need to use DR but have textures on my workstation(not in a network shared folder). Everything works fine: DR server on slave PC receives texture, saves them in Drdata folder and uses for the render.
The problem occurs when I change content of a texture on workstation withuout changing its name. Slave PC continues to use old bitmap stored and render results incorrect. It seems not to recognize textures modified but with same names of previous ones.
Am I doing something wrong?
thanks in advance for helping.
Thanks for reporting, we’ll look into this…
The fix is available in the newest daily build (https://coronarenderer.freshdesk.com/support/solutions/articles/5000570015) and will be also a part of Corona Renderer 4.
Please test this if possible, and let us know if some problems persist.
