Missing Cosmos peeps
Why do my previously placed Cosmos people disappear but they still list in the select object list. Once I re import and place, exit max and then get back into my file I get 2 instances of the same model?
Hi, thanks for posting. Is this happening with a specific model only? Have you tried importing this model in a new empty scene and test the same procedure and share the result. Could you tell us the name of the asset so we can test it on our side.
Trying to remember whether it happened after I updated Cosmos or if it happens when I convert a corona file to vray. Since that’s the current workflow in order to use Vantage. Is there a feature for reloading missing Cosmos proxies?
Hi, can you test a new simple scene with the assets that are causing issues and let us know the results.
Please be careful if you have Corona and V-Ray installed.
When you are using Corona, use the Corona toolbar to start your Cosmos Browser and when you use V-Ray use the V-Ray toolbar. Getting these two mixed up could cause issues.
