when I try to merge old object in scene an error pops up.
Missing dll’s
Filename: vrender2014.dlt Class: VRayMtl. Superclass: 0xC00
Filename: vray2sidemtl2014.dlt Class: VRay2sideMtl. Superclass: OxC00
Filename: vrender2014.dlr Class V-Ray DEMO 3.00.01
I try to convert with coronaconverter but no luck…
I try also to search on internet without success.
Can someone could please help me?
Max 2021 Corona 8.1
Thanks,
Do you have V-Ray installed in your 3ds Max? It doesn’t need to be activated just installed.
First thanks for your fast reply,
yes, I have installed V-Ray for 3ds max 2018 (Demo version).
maru
4
Please install the version of V-Ray for the version of 3ds Max you are using. If you are using 3ds Max 2021, then install V-Ray for 3ds Max 2021.
See: https://support.chaos.com/hc/en-us/articles/4526289638033-How-to-use-the-Corona-Converter-3ds-Max
Thank you Maru,
I did it and the problem is solved!
Bye
