Im trying to network render a job and occasionally the servers bomb out with the error “missing dll: vrayplane60.dlo”
the weird thing is that sometimes machines render fine, other times they dont. Ive had no problems untill just under a week ago…we have had some network changes etc, could this be the cause?
Anyone got any ideas?
The only other thing it could be is that I merged some objects with vray displacement…could have been set up with an older build
ok well check this out for weird…
deleted all geometry and lights, leaving just the direct light and camera and still the vrayplane60.dlo file wont load when i hit render.
interesting that it is looking for vrayplane60.dll (not dlo) though…
im going to try and merge into a new document next to see if that fixes it…corrupt file maybee?
another update…
merging didnt work but I noticed a file called vraplane01 as one of the objects on import
I cant select this object anywhere in the scene…
Basically I cant even render this scene out with scanline. its really weird!
merging to a totally new max file and deselecting the vrayplane01 object when doing so worked…
just have to reset up all of the lights and settings again yay!
apologies for the self answering thread.
maybee this helps someone else who has had similar problems though.?
