missing dll......
hi,
i’am rendering a scene with a looooooots of materials in stripes.
but on all other maschines then that from where i’ve sended he gives me an error: “missing dll scripted plugin - color”.
i’ve installed the plugin everywhere but…
i’ve browsed the hole scene, but can’t find the material where this plugin is used. :x
is there maybe a script which lets me search for a script inside a scene, and select the material/object wich uses it?
thanks
Jonas
ah, found the mat! after 2h of searching :twisted:
but anyways, would like to hear if there’s a script for cases like that.
Wow… the exact same thing just happened to me. I think the script you are looking for is : color_map_plugin.ms
Something tells me morbid is responsible for this problem :slight_smile: (please correct me if I’m wrong… I think its from Morbid’s material library)
