missing dlls
Hi all
I’m working on one of my old project , i’ve used max5 with a bunch of plugins that i don’t use anymore.
whan i open the file i get missing dll on some of cebas plugins , i’ve checked the file and i don’t use any of them + i’ve tried to merge the file to a new file but i still get those.
the problem is that i can’t netrender the file when its in this state.
How can i clean all of this missing dlls?
gili
try http://www.neilblevins.com/blurscripts/blurscripts.htm
within these tools you will find one called “KillMissingModifiers”
Thanks I’ve tried it and it didn’t work
this is the messege that i’m getting.
I’ve looked into the file and there is no trace of final render in there…
check you havent got any final render materials.
don’t have them , i’ve checked.
the strangest thing is that even if i merge into a new file just a box from that file , i’m still getting this messege on the new file
run these commands:
deleteTrackViewNode trackViewNodes.finalRender
deleteTrackViewNode trackViewNodes.tbakerio
And make sure everything fr related is gone too.
/Thomas
check if you don’t have any FR material in material editor or if your light isn’t fr.
surland the first command worked fine and the second did not (“unknown property tbakerio…”)
but it worked and now the file is clean
ty.
gili
