I have a plant library that I’ve been using for years. I’ve never had an issue until upgrading to 2014 and a nightly build. Now whenever I render I get a missing tile error message for EXR files and V-Ray just goes 100% cpu forever. Reverting back to 2013 Maya and any build of V-Ray and the problem doesn’t exist.
[2013/May/10|09:50:52] V-Ray: V-Ray for Maya version 2.25.01, revision 22904 from Apr 17 2013, 05:43:56
[2013/May/10|09:50:52] V-Ray: V-Ray core version is 2.00.02
[2013/May/10|09:50:53] V-Ray: Registered dynamic node vrayMultiProjection
2014x64
Is there any chance some of the meshes in the library to have some exr textures applied or something of the sort? If possible, can you send us say one mesh of this library so we can see this in our environment? Can’t seem to get the same error here.
So this should be fixed for the next nightly builds tomorrow. The rendering will not hang anymore in any case, but you might want to regenerate the tiled OpenEXR files with img2tiled_exr.
I originally created these exrs with img2tiled_exr, however I don’t have the source jpg files anymore, is it safe to redo the corrupt exrs with img2tiled_exr again? Will it repair?
We’re working on a fix for the tool, which will fix your files. We’ll let you know when this is done. For the moment, we’ve fixed V-Ray so it won’t crash when a tile is missing and this should already be in the nightly builds.
