Missing LUT file
I open an old 3ds Max file and the LUT file is missing in the Frame Buffer. It is probably caused by missing the link to a custom LUT file that I have previously used. Is there a way to find out what is the missing LUT file using with some kind of script?
Thanks.
You don’t know how to search files at your PC? =)
Open asset tracker and see all problems with missing asset. after that search that files with native OS search feature
Yes, there is. I would recommend this one: Relink Bitmaps - colinsenner LLC
Check this out:
https://forum.corona-renderer.com/ Corona - Rebus renderfarm | Upload Error
It looks like the LUT may be coming from your Corona Cameras or Render Setup.
