Missing LUT folder
Hi forum,
I recently got a new MacBook Pro and since then, every installation of corona for Cinema 4D doesn’t install LUT presets. I tried to search for a topic here but seems it’s not a common problem. The built in directory is /Library/Application Support/corona/lut
Hi, can you try again with the latest release?
https://drive.google.com/open?id=13xF3PCozC71mO-ky1hnjz6eXYqJJfd3H
Yes, I used the RC 1 but I tried also with the last working version. I also tried with High Sierra on iMac and it works like a charm!
It’s not resolved yet on Mojave, only on High Sierra!!
Sorry, my bad. I’ve moved it back :wink:
I am already using Mojave, and I don’t have this issue. Can you please open “/Library/Application Support/Corona” path in finder (Command + Shift + G) and check whether lut subfolder exists or is empty?
Nikola
Hi Nikola, I checked the folder and there isn’t any LUT folder inside. I think it’s a system issue, like a privacy block or something because neither with the older betas I found the LUT folder.
Solved. it was as I thought, a security issue on Mojave. It didn’t create the folder at first and then was “read only” when I copy and paste from high Sierra.
Glad to hear it’s solved!
I’m encountering the same issue.
I’ve got that message but when I try to open “/Library/Application Support/Corona” path in finder the folder contains only .txt files.
There’s nothing about LUT…
Please help me!
