some materials are missing when I import vrscene to vantage.using latest version of sketchup up and latest version of v ray and vantage.trying to upload screenshots but system won’t let me.
Hi stathis_lazarides,
Can you please send us a sample scene with just a cube and the bricks material assigned to it? There is an issue with UVs coming from sketchup and I would like to check and confirm this is the case here.
Alexander
For example bricks come out as glass / reflective materials
We will need a scene for this. Maybe you have a Blend material on them ? We don’t support it currently.
timber planks and paving slabs come out really small sizes,
This is most likely the (V-Ray for SketchUp specific) issue we are aware of, but still a scene might be helpful.
leaves of trees come out incorrectly
You have to enable clip opacity - it’s the “leaf” icon on the main Vantage toolbar.
Support for the 2-sided material, which is usually used on leaves, is coming soon.
trees missing
Again, we will need a scene.
If you are referencing a .vrscene file from your SketchUp file, this is something Vantage doesn’t support currently.
fireflies…
If you have a sun in your scene, it might help to make it “invisible”. This fixes fireflies issues with V-Ray too.
Greetings,
Vladimir Nedev
