Missing Materials
I have a baffling problem. When I use Enscape on my work pc, all materials render properly. When I use my home pc (which is brand new - same version of Enscape and Revit on both), I get some materials that are grey. Phasing is correct. The realistic view in Revit is correct. It’s not all materials. I am trying to use a standard Revit wood (oak) and shows grey. Also does that with other woods. If I paint the floor red or something that will render correctly. As I am looking at my 3D view, some exterior materials are missing such as standard grass and ground. Grass just shows as “grey” grass. Even the standard asphalt shingles are grey. I did not make any of these custom assets. Also as any fyi these are all in the phase “existing” if that matters.
I copied my Revit project from work to my home pc and same incorrect results. I uninstalled and reinstalled Enscape. I checked my Enscape settings at work and at home and they are the same.
Any insight on this would be great!
I suspect the path to your materials on your work computer is a different path to your materials on your home computer.. You may want to create an additional render path to the materials folder on your home computer.
