Missing mental ray dll warnings
I keep getting warning messages that pop up when I open the scene, or get a new material from the mat editor or add a forest pack object. I know this is not a Vray specific question but this is a new behavior since using Vray5. I just say OK to the warnings and they warning message box closes and then I move on. It’s just annoying and usually have more than one warning to dismiss for these actions. Does anyone have any knowledge of how to keep Max form looking for these mental ray dll’s when using vray?
Use the scene converter which ships with max.
It’s found under the render menu, and has 1-click functions to remove those attribs.
It looks like some of the stuff which is merged/referenced in has the attributes, rather than the main file itself.
We’re investigating our side as well, mind you.
Cool. If you find anything please let me know. My 3DS max is set to open with vray by default. If I click on a vray material in the material editor, then I get those missing mr dll warning messages. I click OK to them and them I get the new vray material and it all work s as should - except for having to Ok those missing mr dll messages.
Does this happen on an empty scene? (i ask as it doesn’t happen here.)
If it only happens with a forestpro scene, perhaps it’s their files which need cleaning.
Lele, it doesn’t seem to happen on an empty scene. Maybe it is FP or possible something to do with all the materials that came across with the revit import. Thanks for folowing up!
It does happen on our scenes as well. No mental ray materials whatsoever in the scene. We all replace them during dataprep. Running the converter also has an effect on the present VrayMaterials?
Edit: Scene converter crashes with the following message:
There should be no need to “convert” as such.
The converter should allow for direct cleaning (it does at least in 2021).
Would you send me a scene (or piece thereof) which crashes the conversion, regardless?
Found out I used the wrong preset. I need to use “incompatible features” instead of V-Ray.
However, we still have a problem with our .mat material library. When opening it in the 3dsMax material browser, we also get a warning. And when using any of the materials from the library, the errors carry over to the scene. But how do I clean up such a material library with around 200 materials?
Eh, the only way i can think of is to make a scene with a piece of geo per material, clean that, and then resave all materials to a new matlib.
Let me see if i can come up with some simple script to do that (at least the scene prepping, and the library saving).
Ok, this is actually easier than i thought.
Open max (i tried 2021. get a demo if the lower versions don’t behave the same), open the scene converter (and leave it open), open the offending material library.
It becomes the current material library, the scene converter detects it, and allows you to clean it with one click.
Save your cleaned material library.
Fantastic, it worked! Thank you very much!
In my case, I’m not sure which material library is causing this. I have two .mat librarys open in the material/map browser. The two are very simple and only have vray materials in them . I think my problem may be being caused by the scene materials that came in with the imported revit model.
I tried what you suggested and now when I choose "get material’ from the mat editor I DO NOT get that missing mr dll warning. So that’s cool. However when I opne the scene for the first time I still need to click OK on about 12 of those warning to get it to open. Once open everything seems good.
Thanks for your help!
The scene converter has an option to automatically remove those attributes on file open/merge.
If you tick it on, the issues should go away after a while, i guess, by virtue of the auto-clean.
Thanks Lele. that option seems to be ticked on by default so I think I had that but the issues remain on file open. I’ll keep messing around with it and post anything I manage to achieve, or not, here.
