I’m a student and just installed the new 2023 max, now I have problem with old scene, I have this error
I’ve tried to undestand why but can’t fix it.
Could you please help me?
Thanks a lot
Stella
It’s very likely that you didn’t install all the plugins that were installed with your old Max version. Try to think what that could be - perhaps Vray bitmap, multi-texture, something else. Unless you install missing plugin, you won’t be able to render the old scene like you did in the older Max.
thank you, yes but how to find what is missing? I can’t find it…multi texture, floor generator, relink bitmap, I’ve re installed but then what else can be?
I don’t know if there is a way to tell exactly what plugin is missing, but if there isn’t then try to think logically. Obviously the plugin must be related to material editor, so that’s not floor generator or relink bitmap (the latter is not even a plugin). Try to think of all non native materials or maps that you may have used in the past, e.g. Siger’s noise and similar stuff.
Thank you so much
when I open the files there’s no error or warning about dll, I got it only when I press render.
What plugin was used to create those materials? That plugin is missing.
If you don’t know what it was - can you open this scene in your previous 3ds Max version where it was working fine?
I don’t have the previous version of max, it was automatically unistalled when installed max 2023. it’s strange it gave the same error with a lot of models that was working fine
Although you uninstalled the previous version, the folder structure might be still on your C>Program Files>Autodesk
If it’s there, just have a look in the Plugins folder to see if anything is different
