I am running into an issue with Enscape that I am not sure how to fix. For some reason geometry in my model fails to properly render and the material appears transparent.
I’ve attached an image showing the issue. The highlighted area on the left is supposed to look like the soil to the top right. Both the left and right of the image use the exact same material and were created the exact same way in Revit. No matter what material I change the geometry to, it will still appear transparent.
Thank you.
