Missing VRayGPUViewportIPR VRay (for 3DS Max 2022)
It isn’t missing for 3DS Max 2021, 2020, but it is missing for 2022.
Please can you advise?
Many thanks.
Hey @JezUK ,
Silly question, but have you made sure your current renderer is set to V-Ray GPU? Have you tried hitting the ‘V-Ray menu registration’ button on the V-Ray toolbar?
You could also try a couple of other things - manually add the option from the Customize UI option > Menus - use the Action list on the left.
Or, delete/rename the ENU folder (this will restore 3ds max settings to their defaults) to see if that changes anything - C:\Users\USER\AppData\Local\Autodesk\3dsMax\2022 - 64bit\ENU
Hi Nikoleta,
Yes, current renderer is set to V-Ray GPU.
But as you can see in the screen grab attached…
It’s not listed in there.
I don’t see it either in the Active Shade menu, but I can enable it by clicking on this option
Max 2022 + Vray GPU 5 update 1.3
This is how I have been using the Viewport IPR with Vray GPU
Best,
Muhammed
Okay, it’s working as expected. I also deleted that missing option entry in the menu pulldown.
Thanks guys.
