The result of the mix map is not what I expected. It is way darker.
V-Ray 6.1
Hello @javierrentas ,
Thank you for the video.
I have tried to recreate similar material in the 6.10.00 V-Ray version and it seems to be working as expected.
Can you please share your scene with material and texture for us to take a look?
Thank you in advance.
I have the latest version of V-Ray 6.10.01 and I had the same mix map issue. Definitely, there is something odd
I’m attaching the material
BronzeBrushed_Metal.zip (145 KB)
Thank you @javierrentas for sharing your material. While I was recreating it I noticed that you have a Color Multiplier set to 0.07.
In material setting Switch to Advanced Settings and change Color Multiplier to default 1 for example.
Thank you!
No idea how that setting was changed. OI only touch those multipliers when the Mode is set to Blend.
Best
