Hello, i try to render a wet road look.
I have one tilable texture (ground asphalt) on map channel 1. I have a glossy map (unwrapped) on map channel 2.
In the bump slot, i try to mix (overlay) the road bump of ground asphalt with the glossy map but it didn’t work!
Can you tell me what i’m doing wrong?
is this stable version? We fixed mix map not working properly in bump, the fix is included in latest daily build
yes ondra, this is 1.5.2 version
ok, so this is most probably fixed in 1.6 daily build, you can either try it now, or wait for stable release
