Mix material does not support Displacement
Hi
Mix material does not support Displacement, it causes Max to crash upon rendering
see http://forum.corona-renderer.com/index.php/topic,2771.0.html
Johan
And I figured out that the CornonaMixTex and the standard Mix material or not equal
Anyone a slolution?
Can you post the problematic scene, or the crashing part? It works for my simple example:
Hi Keymaster
I will have to change the title of this thread. :slight_smile:
After preparing a file for you, where I changed my displacement settings (render settings) back to the defaults one, the file did render with mix map in the displacement slot. But If I lowered the displacements settings so I would get less displacement, Max is crashing.
Is this normal? If can still send you the file when you need it.
send send send send send! :wink:
Any progress? Do you have the scene?
Hi Keymaster
I have send you the file a while ago. (via the upload folder)
But in the meantime I have tested it with the daily builds and now it works fine.
cheers
johan
Coolio
