Hi, i’ve just started to use Corona and love it a lot , but i’m a little bit stuck now , i try to make a dirty material and the “mix” map seams to not
be usable with corona
Do you guys have a solution/alternative for that ? i don’t want to use vray anymoree
Corona has a “CoronaMixTex”
Yes ! thanks Boris it’s working very well
Hum another things, does corona have an equivalent of the ward or blinn shader for metal material creation ?
Ah ! THanks for the advices Rawalanche it’s working pretty well ![]()
I need to make a car paint style shader - i cant work out how to layer up the materials - the 3ds max blend is not seeming to work. I looked up some car paints on this forum and downloaded the example files but they wont load
Any help appreciated
